crank no start on my lt1 rebuild
Old Jul 16, 2005 | 03:15 PM
95z28txn's Avatar
Cranks But Won't Start. Here Is The Situation. Fresh Rebiuld On A 95 Lt1. I Have A New Icm And Opti. Pretty Sure The Timing Is Good. I Have Fuel Pressure To The Fuel Pressure Reg. But Not Sure If I Do After The Reg. It Won't Even Start If I Use Carb Choke. It Cranks And Tries To Start For A Second But Then Goes Back To Cranking. The Cranking Will Slow Down And Speed Up Though. What Do I Check Next? The Three Main Grounds Seem To Be Good. Can I Ground The Pcm Strait To The Neg. Term. On The Batt.
BEFORE I REPLACED THE ICM AND OPTI IT NEVER TRIED TO START.
Old Jul 16, 2005 | 04:02 PM
fast 93 z's Avatar
Re: crank no start on my lt1 rebuild
When you installed the new opti........did the cam dowl pin go in the correct slot in the opti drive?
Old Jul 16, 2005 | 04:03 PM
95z28txn's Avatar
Yeah I Think It Did But It Is Really Hard To Make Sure. Should The Opti Be Completely Flush With The Timing Cover Before The Bolts Are Tightened.
Old Jul 16, 2005 | 04:15 PM
fast 93 z's Avatar
Yes....it should be flush.
Old Jul 17, 2005 | 11:26 AM
95z28txn's Avatar
I Put The Opti In Right And Now It Works! Thanks For The Help.
Old Jul 29, 2005 | 10:47 AM
fast 93 z's Avatar
No prob man.....glad I can help.
Jessie4tin
Jan 7, 2015 08:53 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Not Dave
Dec 11, 2014 06:32 PM
thenewkid
Nov 27, 2014 09:41 AM
1LEThumper
Jul 14, 2003 12:45 PM
