crank key question
Old Jul 20, 2007 | 12:38 AM
mkent's Avatar
crank key question
My motor is basically put together, but I was just looking closer at the crank hub and noticed that I probably have a problem.
It's a 97 LT1 with a new forged Scat Crank. I removed the CPS reluctor ring and also used a standard crank key rather than the LT1 specific. I'm pretty sure the hub snout is going to hit the key before it seats correctly.
So should I remove the timing cover and crank gear to put the correct key in it? Should I notch the hub so it slides past the woodruff key? I don't want to have any aligment problems where I'm shredding serpentine belts
Old Jul 20, 2007 | 07:14 AM
Guest47904's Avatar
Guest
Need a different key
To my knowledge, you will need a different key.
Old Jul 20, 2007 | 10:47 AM
The Engineer's Avatar
You could also use an aftermarket LT1 keyed hub. I'm using the Jeg's brand keyed hub and SFI under-drive damper.
WD
Old Jul 20, 2007 | 11:54 AM
mkent's Avatar
WD
Wouldn't the rotating assembly need balanced again if I went this route?
Old Jul 20, 2007 | 12:08 PM
mkent's Avatar
No one seems to have these keys in stock. It looks like I'm done working on this thing until Tuesday. Or I can continue beating on the stock one and hope it finally pops out--its getting pretty chewed up though. Dal at VanDevere is my last hope but it's hardly worth driving 2 hours to get there for a $6 part!
Old Jul 20, 2007 | 12:55 PM
No! LT engines use a harmonic “damper” not a “balancer” on the front crank hub. And, I don’t believe dampers ever have to be balanced (to match) with the crank. I like using the keyed LT-1 type hub so you don’t have to worry about it slipping, if you ever need the timing reference.
WD
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
