AIR delete quick fix...
Old Jul 7, 2007 | 03:27 PM
AtotheJ3's Avatar
Ok the lowdown: I've taken my car apart to do the opti, plug/wires, 160 therm, TB bypass. I'm putting it all back together now and now I'm thinking about deleting the AIR pump.
My question is this, can I just take the pump and remove all the rubber hoses attached to it? I know I'll have to cut the metal air tube, but I just don't feel like doing it right now.
Also, what am I going to need to plug up if I just remove the rubber hoses and what do I use to plug it up? Right now all I know is that I need a 3/4 vacuume cap for the CAI.
thanks
Old Jul 7, 2007 | 04:56 PM
JAKEJR's Avatar
I just deleted the A.I.R. from the 388 LT1 I just built for my 96 Vette. I don't know if your exhaust manifolds are the same as mine, but I bought plugs from my local DODGE dealer - 22 mm - designed for a Dodge turbo diesel with a Cummins (sp) engine.
They screwed right into my stock exhaust manifolds. About $9 each.
I had BRYAN at PCMFORLESS turn off the A.I.R. in my PCM when he re-programmed it for the new engine.
Hope this helps.
Jake
Old Jul 7, 2007 | 05:58 PM
bmwmcars's Avatar
i just hammered a nickel into them, a 5 cent plug
Old Jul 7, 2007 | 06:03 PM
wrd1972's Avatar
Hope this helps.
Jake
These metal plugs are much cheaper at a shop that specializes in hydraulics.
Old Jul 7, 2007 | 06:47 PM
mrseven's Avatar
Here's another thread on it:
http://web.camaross.com/forums/showt...light=air+pump
Old Jul 8, 2007 | 01:05 PM
JAKEJR's Avatar
Then the 'F' and 'Y' body cars ARE significantly different, at least on my 96. The holes in my manifolds would be closer to the size of a half-dollar.
I DID use the nickel trick to block off one of the EGR holes in my other Vette, a 86, though. Worked like a charm.
Jake
Old Jul 8, 2007 | 05:43 PM
bmwmcars's Avatar
Jake
not sure, the car was a 95 z28.
Old Jul 20, 2007 | 12:31 AM
carriedaway's Avatar
I found these on ebay:
http://cgi.ebay.com/ebaymotors/ws/eB...1143630&rd=1,1
Old Jul 20, 2007 | 01:26 PM
JAKEJR's Avatar
Originally Posted by carriedaway
Those look much like the ones I bought (different head; mine were female hex), but those cost half as much as I had to pay.
Jake
DirtyDaveW
Dec 1, 2016 05:37 PM
HarleyZ28
Oct 5, 2015 06:23 AM
armedtrigger
Feb 24, 2015 08:30 PM
95chwagon
Jan 13, 2015 09:19 PM
cmdeshon
Dec 27, 2014 10:06 AM
