Crank hub stuck? help please!
Old Oct 27, 2005 | 12:08 PM
Colin91Z's Avatar
I tried searching first, but cant figure out where I'm going wrong the motor is on a stand, so space isn't an issue. I have been using the crows foot style puller and have now destroyed two of them. The threads on the center bolt of the puller keep in stripping, (yes I have lubed the threads) and the hub hasn't budged a bit. I used the original crank bolt to push off of, but removed the washer. I have used this method before on a friends 94 LT1 and it worked fine, is there something different about my 96? Does anyone have any ideas? Please Help!!!
Old Oct 27, 2005 | 12:19 PM
Gripenfelter's Avatar
Re: Crank hub stuck? help please!
Make sure there is no center bolt holding the hub on.
Old Oct 27, 2005 | 12:25 PM
Colin91Z's Avatar
There isn't, even with the crank bolt in there (with no washer of course) I can look in there with a light and see that it clears the hub itself, so its not holding it on. Is there any reason that I'm missing why a longer bolt to push off of would work any better than the original crank bolt itself?
Old Oct 27, 2005 | 12:27 PM
Evil Eric's Avatar
Heat it up with a torch and tap it with a hammer.
Old Oct 27, 2005 | 12:31 PM
Colin91Z's Avatar
I tried that too it didn't help, or maybe I didn't get it hot enough
Old Oct 27, 2005 | 01:33 PM
slverbullet's Avatar
try using a 1/4" extention (like a 4" to 6" one) down in the hole at the end of the crank. use that to put the center piece of the puller on (the open end of the extention, where you put the wrench, should be facing out. put the puller center piece in that). then crank it out that way. thats how i did mine and it worked good.
NeverEverSatisfied's Avatar
You could always cut it off...
Old Oct 27, 2005 | 01:41 PM
Colin91Z's Avatar
Thanks, I'll try this when I get home and see if it helps
Old Oct 27, 2005 | 01:44 PM
Colin91Z's Avatar
I was so frustrated with it last night that I was just about ready to remove it with a stick of dynamite ...but today is a new day so we'll see...
Old Oct 27, 2005 | 01:46 PM
turbo_Z's Avatar
Yeah it sounds like you just need a longer bolt or that extension trick should get it.
Old Oct 27, 2005 | 02:17 PM
96ta(nick)'s Avatar
Use a stronger puller maybe?
Old Oct 27, 2005 | 02:26 PM
Colin91Z's Avatar
I thought of that after I broke the first one, so I went and got the strongest most expensive one I could find and it broke exactly like the cheap one did. Thats why I think the problem is something else or I'm doing something wrong. Thank god for the lifetime warranty on most tools from O'Reillys
Old Oct 27, 2005 | 02:43 PM
turbo_Z's Avatar
Yeah it sounds like you are pushing against the hub itself instead of against the crank.
Old Oct 27, 2005 | 02:47 PM
Colin91Z's Avatar
Could be...I went and got a 4" long grade 8 bolt to stick in the crank snout on my lunch break, I guess I will find out if it works when I get home...
Old Oct 28, 2005 | 08:28 AM
Colin91Z's Avatar
Well, the 4" bolt worked for anyone else who does a search and finds this thread, it was a grade 8 bolt, 5/16 thread by 4" long. Thanks everyone for you advice
Boss002
Jan 20, 2016 12:17 PM
jbert55
Oct 31, 2015 03:52 PM
Boss002
Jul 24, 2015 10:47 AM
RallyRed701/2
Jul 20, 2015 11:18 AM
Catmaigne
Jul 14, 2015 05:17 PM
