Crank Hub STUCK
Old Jul 15, 2008 | 12:04 PM
96' Formula WS6's Avatar
Crank Hub STUCK
Doing the cam swap for the first time, everything was going silky smooth until I got to this hunk of junk. So I was battling this thing all night last night. I searched and found that people put either a grade 8 bolt or a 1/4 inch extension. I opted for the extension route. Well it was working and I got it about a quarter of an inch off then the extension broke. So I had to hammer the hub back on and that slipped out. So I tried it again hoping that since I got some movement out of the hub it would come off easier. Well the extension got smashed up before the hub even moved this time. So I dont know how to get this one out of there. Any ideas? Also I was talking to somebody out there and they reccomended a special gm/LT1 style puller. Has anyone tried that
Old Jul 15, 2008 | 12:49 PM
crazypurgatory's Avatar
I just use a harmonic balancer puller.
http://www.harborfreight.com/cpi/cta...emnumber=37824
Just 10 bucks.
Old Jul 15, 2008 | 01:12 PM
Yea thats what Im using, not that exact one but one like it. Thats a nice kit for 10 bux though. Any thoughts on how to get the extensioin outta there
Old Jul 15, 2008 | 01:31 PM
Well I'm kinda lost on what you did.
I know what your trying to do.
The extensioin is stuck where?
Old Jul 15, 2008 | 01:54 PM
Yea it kinda shattered and I cant seem to get this one out like I could the last one.
Old Jul 15, 2008 | 01:57 PM
jclark311's Avatar
Be carefull not to damage the threads on the crank, try heating the damper hub with a propane torch.
Old Jul 15, 2008 | 02:11 PM
ulakovic22's Avatar
Did the extension mushroom out in the crank and that's why it's stuck? Is there any room so you can thread any kind of bolt into the crank?
Old Jul 15, 2008 | 02:19 PM
ShownomercyZ28's Avatar
Yea you gotta get a bolt in the crank hub to have the puller push against.
Old Jul 15, 2008 | 02:28 PM
yea it looks like it mushroomed out, I really hope i didnt mess anything major up. With the extension in there I cant get another bolt in there. and I was heating it up as I had the impact on it but that didnt help much
Old Jul 15, 2008 | 02:45 PM
RUDEDOG's Avatar
You are using terms like smashed up,shattered, and mushroomed out. Can you post a pic? That metal has to be removed and threads repaired if necessary. If we could see it we might be able to help. The only other solution is take it to a machine shop or replace the crank. That bolt has to be installed.
Old Jul 15, 2008 | 02:46 PM
ulakovic22's Avatar
You need to get the extension out before you move any further. Does the extension rattle around in there or is it jammed in there pretty good? You might be able to heat it, the extension that is, and pull on it with something like pliers/channel locks and hope it gets soft enough to pull out.
Old Jul 15, 2008 | 04:26 PM
Its jammed in there pretty good, no I cant move it around at all and it doesnt rattle. Give me a couple of minutes I should be able to get a pic up. Is there any way to get the hub off without pushing against the center of the bolt. O yea and it is pretty flush with the center of the bolt hole and I cant grab it with even a needle nose pliers
Old Jul 15, 2008 | 04:27 PM
This is why extensions are never a good idea. I have read many posts of them getting jammed in the hub. An old head bolt with the threads ground off makes a decent "rod" to slip in the hole for the puller to push against.
If there was room to do it, a slide hammer might get it off.
Old Jul 15, 2008 | 04:43 PM
Thanks shoebox, are you talking about the slide hammer to get the hub off or to get the extension out. Im not sure what a slide hammer is. At this point I dont care about the hub as its already messed up and I can get a new one. Im just trying not to damage the crank. Here are the pics I promised
Whoa those are huge, sorry I dont know how to resize
Old Jul 15, 2008 | 04:45 PM
You can kind of see the extension in there, its the shiny part way down in the hole.
