crank hub,,please help im going crazy
help please,
ive tried everything i could think of to get this damn hub off,
can anyone please help me or tell me how or what worked for you.
seems like its not budging at all, im using a puller,
thanks,
josh
thanks,
josh
DO NOT put the pressure on the threads... I ended up having to helicoil the hole for that bolt in the crank. Instead, get a strong bolt that will hit the end of the hole so it will push on the crank instead of the threads. It's a fine thread hole so it strips easy especially with a grade 8 bolt and a soft crank.
What i have found to work best was use a pulley puller from Autozone, take the hub bolt out ,use a smaller bolt to push against the crank ,then go buy longer bolts ( grade8) thread them through the crank and put a nut on the back of each bolt. That will help make sure you don't strip anything out and the pulley will come off easy..... To put the pulley back on all you need to do is buy a 12 inch long grade 8 allthread, a few flat washers and nut to press it on don't waiste your $ on an installer.
NewsBot
Jul 29, 2015 08:10 PM
Catmaigne
Jul 14, 2015 05:17 PM
