Crank hub install
Old Jan 15, 2009 | 06:16 PM
01pewterz's Avatar
Crank hub install
When putting the crank hub back on does it have to line up with anything? Its not keyed, but I was just wondering since I stuck it back on, do I need to pull it back off and reposition it?
Old Jan 15, 2009 | 06:37 PM
Only if you want it to line up for judging TDC, like when adjusting valves and such.
Old Jan 15, 2009 | 08:36 PM
01pewterz's Avatar
ok well I'll just leave it then, I think its lined up w/ #6 TDC right now
Old Jan 15, 2009 | 09:20 PM
Stl94LT1's Avatar
Just a tip. While you have it at TDC, mark the balancer with a paint pen so you can easily find it again. TDC for #6 is also TDC for #1. Just compression vs exhaust strokes.
Old Jan 15, 2009 | 09:37 PM
That's the same thing. The crank rotates twice for every time the cam does. 1 and 6 TDC are in the same position as far as the crank goes.
HectorM52
Jul 30, 2017 11:46 AM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
1LEThumper
Jul 14, 2003 12:45 PM
