Crane roller rocker adjustments
Old Jul 16, 2004 | 02:31 PM
96WhiteZ28's Avatar
Starting to loose hope with these....
I adjusted all the roller rockers with the car running. I then tighted the poly locks with the allen key tight. Put everything back. Drove around for about an hour... the car ran nice no problems... after about an hour i heard a knock from one of the rockers. Why did it come loose??? Did i tighten the poly locks down too much? These are the Crane Gold Self-aligning 1.6 roller rockers. I'm running stock springs (only 26k miles on car) and pushrods.
Old Jul 16, 2004 | 07:07 PM
96WhiteZ28's Avatar
anyone
Old Jul 16, 2004 | 07:18 PM
Pasky's Avatar
Heat cycle, completely normal. I had to do it about 3 times, no more knocks.
Old Jul 16, 2004 | 07:19 PM
96WhiteZ28's Avatar
Thank god lol... it is annoying having to take the alternator off every time lol that $200 relocation bracket doesn't seem so expensive anymore
Old Jul 16, 2004 | 07:21 PM
Pasky's Avatar
LOL, tell me about it. I hated that part. I figured out I can just loosen the bottom one nearest the fender and take the top one off and the serpantine belt off and just pivot the alternator out of the way.
Old Jul 16, 2004 | 07:29 PM
96WhiteZ28's Avatar
Alright well thanks a lot. I was getting a little scared that i was never going to have these rockers on right.
Old Jul 17, 2004 | 12:58 PM
96WhiteZ28's Avatar
Last night i had to pull the valve cover off for the 5th time. One rocker got loose... extremely loose... the nut just comes off the rocker and its totally free. I took the allen key and i brought the inner screw up... tightened it again... brought the allen all the way down again. (Am i suppose to bring the little allen plug in the rocker's nut down all the way tight?)
Now i drove the car for about 30 minutes and i started getting major ticking again. I drove pretty far away from home and i had to drive for 10 minutes with the ticking. The check engine light came out and the car ran horrible. I'm going to pull the valve covers off again today and see if it was the same one that got loose. I got the adjusting part down now but why are they coming loose on me!???!??!?!?
Any help would be greatly appreciated!
Old Jul 17, 2004 | 04:22 PM
96WhiteZ28's Avatar
Anyone please??
Old Jul 17, 2004 | 05:13 PM
Pasky's Avatar
Ok, are you using a hand allen wrench or a ratchet? if your doing it by hand, go to sears and pick up a ratchet. Pull the valve covers, loosen all the allen bits on the rockers. Now loosen the hex bolts on the rockers then tighten them hand tight. Start the car. Hand tighten all the hex bolts until you don't hear any clicking. Now tighten them 1/4 or 1/2 whatever your rockers say to do on the hex bolt on all of them. You can now shut the car off or leave it on. Now tighten the **** out of the allen bits with the ratchet. I gaurantee they will not come loose.
Old Jul 18, 2004 | 02:02 PM
96WhiteZ28's Avatar
Actually that's what i have been doing and it wasn't the way it was suppose to be according to a website i found. The website said to tighten the hex down until it doesn't tick and then 1/4.... then it said to tighten the allen bolt down with the allen key. After the allen bolt is tight then tighten the hex another 1/4 turn. It says that that causes pressure from the allen screw unto the hex nut and keeps it locked in place. It did it this morning and drove the car around for about 2 hours and everything is running fine The tires peel nicely from a roll now when the car is fully warmed up... rips the pavement up when the car is cold... awesome mod!!! Next is tune from madz28.com which i'm ordering on Friday as soon as my direct deposit is in!!!
Chevyguy358
Parts Wanted
Jul 20, 2015 07:42 PM
JCSWS6
Jul 19, 2015 06:47 PM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
