Crane HP Hydraulic Roller-Lifters
Old Jan 16, 2008 | 03:51 PM
  #31
Kevin97ss's Avatar
Changing preload changes rocker geometry. There is substantial power to be had in correct geometry. The engine Crane did there testing with may have had the best geometry at 1 turn past zero lash thus making the most power. It does not necessarily mean all engines with their lifters will make the most power at 1 turn.
Old Jan 16, 2008 | 05:16 PM
  #32
The Engineer's Avatar
Excellent point on the rocker geometry! Therefore, the best approach for me will be to test several different preload settings and then determine which one works best for my application 1/4, 1/2 or 1 turn.
WD
Old Mar 13, 2008 | 01:54 PM
  #33
ssean92's Avatar
did you ever get back to the track????
Old Mar 14, 2008 | 09:08 PM
  #34
Yes, and I've got an opinion on Crane's tech advice about the heavy preload (1 to 1-1/2 turns).
Bottom-line, the heavy preload "does not" improve the high RPM performance with the Crane HP lifters. And, possibly the one turn of preload (.050") hurts the high PRM and something around .015 to .020 would be best.
Also, I added some new hardware to my valve-train, besides the new PAC-1518s. The performance improvement was significant!
WD
Old Mar 16, 2008 | 10:39 AM
  #35
truedualws6's Avatar
TPIS did a lot of dyno and track testing with lots of lifter preload and had
some very interesting results that are in line with the Crane recommendation.
I've played around a bit with 1.5 turns on a stock GM lifter and it seemed to
agree with the TPIS findings. I would say 1 turn is a very reasonable preload
without going extreme. I set my GM lifters to 1 turn now (with 7/16 studs).
Old Mar 16, 2008 | 11:25 AM
  #36
ssean92's Avatar
can you guys look at my post about my 383 and see what you think
Old Mar 16, 2008 | 01:29 PM
  #37
SS RRR's Avatar
Originally Posted by The Engineer
I'm still not sure why Crane is recommending 1 full turn to 1 1/2 turns for thier performance lifters????????.
WD
Because it may be a precautionary measure so they don't get smeared like Comp from those who had valvetrain troubles to start? Just a guess...
Old Mar 18, 2008 | 10:23 AM
  #38
Yeahdoug's Avatar
WD
Awesome set up.
G-BODYT56
Jan 14, 2022 11:14 PM
95chwagon
Oct 16, 2015 12:24 PM
Z Power
Sep 19, 2015 11:19 PM
bunker
Aug 21, 2015 10:21 AM
