Crane 270-10308-1
Old Sep 16, 2007 | 07:14 PM
extreme79z's Avatar
Crane 270-10308-1
Will this work for cc305, s/a1.6rr's and stock heads? I'm kinda in the dark here?
Jegs part 270-10308-1
Old Sep 16, 2007 | 07:19 PM
speed_demon24's Avatar
Yes, but I don't like that kit since it just uses shims instead of spring seats so the valve springs walk around on the heads.
Old Sep 16, 2007 | 07:29 PM
extreme79z's Avatar
Yeah, I'd have to say that isn't a good thing... Is there a better kit? I am buying some in the next 24 hours, so I'm cramming trying to learn something about them. lol I just liked that because it was a complete kit and was very reasonable.
9formula4's Avatar
the 10308 is made to fit the stock seats. They do not walk aorund on the head they have been working GREAT on my car with a 503 and others also running the same spring/cam combo.
Old Sep 16, 2007 | 07:32 PM
extreme79z's Avatar
Thanks for the words 9formula4, do you have any track times with that cam... That's what I wanted to get, but ended up getting it's little brother (305)
Old Sep 16, 2007 | 07:37 PM
9formula4's Avatar
no track times yet. Had to get a stall before I could hit the track with it. I will say however it is quite a good cam for street and strip. i have done a few runs on dead highways with itand it seems to get the job done with plenty to spare.
Old Sep 16, 2007 | 07:50 PM
Then explain why all my valve springs were wedged sideways when I had that kit on my car. Our cars come stock with valve seats, this kit is a downgrade from stock. You can use the comp spring seats for 1.5 od springs and grind a little bit off the seats and they will fit perfectly.
Old Sep 17, 2007 | 04:09 AM
<Puck>'s Avatar
If installed properly they should not walk around on the heads. Only way I can see that happening is if you use guideplates and different locks then the kit supplies, and your valvetrain geometry is off. The shims are thin because the spring is taller then stock, and they give them the correct installed height.
I run the 10308 set with a custom grind bigger then the 503, with crane gold SA 1.6rrs, and have not had a problem in a year of using them in my DD that gets strip time.
Old Sep 17, 2007 | 08:04 AM
Bersaglieri's Avatar
I have never heard a problem with the Crane 10308 Spring Kit, nor have I had one with mine and a CC306 w/ 1.6 NSA Pro Mags. Its a very good spring kit in my opinion, especially for the price. I'd use it with a XE503, it also gives you some room to grow.
-Dustin-
Old Sep 17, 2007 | 08:12 AM
Daniel6718's Avatar
i used them and spu my 306 cam to 7k for 2 years...no problems here
i didnt even use ths shims....i think i used the factory seats
Old Sep 17, 2007 | 02:44 PM
<Puck>'s Avatar
Musta been a ton of seat pressure with stock valves - they are pretty tall!
95chwagon
Oct 16, 2015 12:24 PM
bunker
Aug 21, 2015 10:21 AM
detroit1994z28
May 14, 2015 12:09 AM
nikolt1
Feb 27, 2015 09:10 PM
