cracked elbow, will trick flow fit on 1993 LT1 with SLP CAI??
does anyone know for sure if the trick flow elbow will fit no problems on a 1993 Z28 with an SLP cold air intake?
If it wont work, I'll just order a 1LE unit.
I took my CAI and elbow off today to clean the air filters, and noticed the underside of the elbow around where it goes around the TB is all cracked and ripped. There has to be an air leak there so I'm gonna change it.
It will fit without a problem on your '93... it fits on my '96 (I have a GMPP intake, but it's the same thing as your SLP) Check my sig and see some pics
You'll have it easy because there's no MAF to deal with. You'll just use up a lot of that bridging rubber that comes with the elbow, but it should fit fine. In the pic I have I trimmed about an inch and a half of rubber and there's still a lot on there.
Good luck!
Good luck!
