Cracked the accessory bracket
Old Oct 23, 2003 | 10:33 PM
ollie-99's Avatar
I cracked it right where # 48 is from this link
http://csce.uark.edu/~jgbertr/rb/accessory_bracket.jpg
Right were the thread goes so its like cracked in half there
is it still ok to run everything w/. the cracked bracket?
if not how hard is it to replace>
Old Oct 23, 2003 | 10:42 PM
turbo_Z's Avatar
it took me a little while to pull one off a motor that was sitting outside on a stand so trying to replace one still in the car will definitely be a complete bitch.
Old Oct 23, 2003 | 10:45 PM
ollie-99's Avatar
screw it then
im leaving it
Old Oct 23, 2003 | 11:22 PM
Since the crack sounds like it is up on the top, you could probably have it welded by a competent aluminum welder without taking it off.
Old Oct 23, 2003 | 11:38 PM
Dave89IROC's Avatar
yeah, if it is through the threaded hole, i would have it welded solid, then drill and tap a new hole, tada, better than new
Old Oct 23, 2003 | 11:44 PM
ollie-99's Avatar
ok good plan
Old Oct 23, 2003 | 11:48 PM
Z95m6's Avatar
I don't remember it being that hard I guess that is why i let you work on that part while i took off the easy stuff.
Old Oct 23, 2003 | 11:51 PM
turbo_Z's Avatar
well unbolting it wasnt but all the hoses from the PS and AC made it tricky.
Fastbird93
Apr 9, 2016 07:01 PM
Noct
Jul 14, 2015 01:18 AM
colts0455
Jul 8, 2015 12:21 AM
robyyzpapa
Jul 7, 2015 10:05 AM
CARiD
Jul 7, 2015 08:19 AM
