Cracked the accessory bracket
I cracked it right where # 48 is from this link
http://csce.uark.edu/~jgbertr/rb/accessory_bracket.jpg
Right were the thread goes so its like cracked in half there
is it still ok to run everything w/. the cracked bracket?
if not how hard is it to replace>
Originally posted by turbo_Z
it took me a little while to pull one off a motor that was sitting outside on a stand so trying to replace one still in the car will definitely be a complete bitch.
im leaving it
Originally posted by Dave89IROC
yeah, if it is through the threaded hole, i would have it welded solid, then drill and tap a new hole, tada, better than new
I guess that is why i let you work on that part while i took off the easy stuff.
Originally posted by Z95m6
I don't remember it being that hard
Noct
Jul 14, 2015 01:18 AM
CARiD
Jul 7, 2015 08:19 AM
