CR calculator
Old Apr 10, 2013 | 09:44 PM
  #31
RamAir95TA's Avatar
Re: CR calculator
4.00" bore, 3.48" stroke, .015" shim gasket, .020" in the hole (what I've measured on two blocks, give or take a few .001s"), 56.6cc (including the 4v reliefs) = 12.0:1.
Old Apr 10, 2013 | 09:49 PM
  #32
redline9570's Avatar
Re: CR calculator
Originally Posted by RamAir95TA
4.00" bore, 3.48" stroke, .015" shim gasket, .020" in the hole (what I've measured on two blocks, give or take a few .001s"), 58cc (including the 4v reliefs) = 12.0:1.
I thought stroke was 3.75 I'm getting 11:25 http://www.wallaceracing.com/cr_test2.php
Old Apr 10, 2013 | 09:53 PM
  #33
RamAir95TA's Avatar
Re: CR calculator
Stock block has a stroke of 3.48"...
Old Apr 10, 2013 | 10:05 PM
  #34
97 6SPEED Z's Avatar
Question Re: CR calculator
We can play with STOCK deck clearance numbers all day, (I also have measured two (2) LT1 blocks, and the deck clearance varied from cylinder to cylinder by .002" but averaged that prevoiusly stated .025"), but ...... how can you TOTALLY ignore that 7cc of stock piston relief volume???
Old Apr 10, 2013 | 10:08 PM
  #35
Re: CR calculator
the chamber volume is 56.6 + 7cc he figured 56.6 with relief cuts. This all just seems to be a numbers game in the end time slip tells it all.
  #36
RamAir95TA's Avatar
Re: CR calculator
I stand corrected, but the stock volume is 4cc. With those corrected figures we end up with 11.6:1 - still FAR better than the 10.6:1.
That's an easy 10-12whp difference.
Old Apr 10, 2013 | 10:15 PM
  #37
Re: CR calculator
I'm getting 11.4 but we can go at this all night, in the end it will come down to who has a better calculator and least amount of beers.
Old Apr 10, 2013 | 10:21 PM
  #38
Post Re: CR calculator
Well, we are having a great discussion here, but ........ I have to respectfully disagree.
While I haven't personally cc'd them, I've looked at those four(4) STOCK piston valve reliefs often enough, and believe me ........ they are bigger than 1cc each.
Old Apr 10, 2013 | 10:23 PM
  #39
Re: CR calculator
I figured they are about 6-8 cc and it makes a big difference in the outcome.
Nayr
Mar 3, 2023 08:34 PM
Flint78
Jun 21, 2015 01:28 PM
kosta
Jun 5, 2003 11:01 PM
neversummer
Feb 21, 2003 07:27 AM
stevil
13
Sep 24, 2002 11:31 AM
