CR calculator
Re: CR calculator
4.00" bore, 3.48" stroke, .015" shim gasket, .020" in the hole (what I've measured on two blocks, give or take a few .001s"), 56.6cc (including the 4v reliefs) = 12.0:1.
Re: CR calculator
We can play with STOCK deck clearance numbers all day, (I also have measured two (2) LT1 blocks, and the deck clearance varied from cylinder to cylinder by .002" but averaged that prevoiusly stated .025"), but ...... how can you TOTALLY ignore that 7cc of stock piston relief volume???
Re: CR calculator
Re: CR calculator
That's an easy 10-12whp difference.
Well, we are having a great discussion here, but ........ I have to respectfully disagree.
While I haven't personally cc'd them, I've looked at those four(4) STOCK piston valve reliefs often enough, and believe me ........ they are bigger than 1cc each.
Nayr
Mar 3, 2023 08:34 PM
stevil
13
Sep 24, 2002 11:31 AM
