CPS Reluctor?
Old May 26, 2010 | 10:49 PM
bds001's Avatar
CPS Reluctor?
What exactly is this thing used for?
And does anyone know where to get a new one along with a new woodruff key and any idea how much they'd cost?
Thanks for any info. Got some damage to these, not really sure how
Old May 26, 2010 | 11:05 PM
Dave1980's Avatar
I have one. Pm me I will let it go for cheap.
Old May 27, 2010 | 05:06 AM
The crank position sensor (CKP) consists of a Hall-effect pickup in the bottom of the timing cover and the reluctor gear on the crank. It's only on the OBD-II engines (96/97) and its used by the PCM to identify misfires. The PCM compares the minor crank rotational velocity changes to the known firing pattern for the engine, and determines if there are velocity changes outside the normal range, indicating a misfire. The engine will run without it, but you will have an SES light, unless you have the code programmed out of the PCM.
Old May 28, 2010 | 11:35 AM
texas97z's Avatar
Oreilly's sells the woodruff keys. My local lowe's sells them as well for a bit cheaper, so you might want to try there as well. They are in the hardware section where all the nuts and bolt are.
Old May 29, 2010 | 01:17 AM
bds001's Avatar
thanks for the info guys
got the plate today from GM, and gonna try the Lowe's/O'reilley's for the key
Old May 29, 2010 | 08:58 AM
Dave1980's Avatar
Curious on how it got messed up.
Old May 29, 2010 | 10:29 AM
Don't know the answer, because my 94 doesn't have the reluctor, but is the reluctor held in place by the longer extension on the crank sprocket key? Is it possible the wrong key was used?
Old May 29, 2010 | 01:40 PM
I'll make a wild guess based on the pics in the thread. The crank key looks like it has no cut-back (just a little gouge on the end). If so, the key would have stopped the hub from sandwiching the reluctor flat to the crank gear. The small space left allowed the reluctor to wobble and wallow until it came free from the key and flailed around creating the damage to the inside ring.
realistyc
Jul 28, 2015 07:32 PM
markzzzz
May 8, 2015 09:21 AM
Queens94z28
Dec 20, 2014 09:11 PM
QCKZ28
Mar 18, 2004 03:26 PM
bad96firechikin
Oct 3, 2003 09:40 AM
