A couple ?'s
Old Apr 8, 2009 | 02:24 PM
joshmullins8's Avatar
Question A couple ?'s
Im about to rebuild my 94 A4 Z28 and do .30 over pistons and LT4 Hot Cam and a couple bolt ons and use the car as a daily driver, I was wondering what gears I should run 373's or 342's? Also I need to know if my rear is a 2 or 3 carrier and is it a 7.5? I have no idea, also what size torque converter should I run a 2400 or 3000. Im new at all this since Im only 17 and building my first car by myself so please help me by answering my questions, thanks Josh
Old Apr 8, 2009 | 03:53 PM
bombebomb's Avatar
Since you are young and still new to the car world I will correct a few things for you which will help you on down the road.
Its .030 over (thousanths) not .30 (hundredths).
I think 3.73's are a good overall gear
To determine if you have 2 or 3 series carrier, see if you can put your car in Drive 1 (on the shifter) if it only goes to drive 2, then you have stock 2.73's 2 series carrier. If you can go into Drive 1 then you have Stock 3.23's with a 3 series carrier.
Your rear is a 7.5
Most people recommend 3000rpm stall converter for stock (or street).
Since you have no one to help you I suggest you to ask lots of questions.
Old Apr 8, 2009 | 11:51 PM
Chevyguy358's Avatar
yea for an A4 3:73's just perfect...for a M6 more like 4:10's
Old Apr 9, 2009 | 06:58 AM
The rear is actually a 7.65, but people call it a 7.5, too.
Old Apr 9, 2009 | 05:23 PM
lr383's Avatar
3.73 will work fine for you. You can get gears to go with your carrier I had 2.73 in mine . 2500 to 3000 stall will work well.My son`s ta as this combo with hot cam it haul`s ***.
Old Apr 9, 2009 | 06:33 PM
Thanks alot for all your help.
And lr383 if you dont mind me asking do you know what his TA is running in a 1/4 ?
Old Apr 10, 2009 | 08:17 AM
lr383's Avatar
He runs 13.62 at 104 mph that`s at 2300 alt. above sea level. he has nos on it but can`t get tires under it. if you go with that combo you should have lot`s of fun. just little info with 3.73 at 80mph you be a about 3 grand .
Sep 27, 2015 01:55 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
Slayer
Aug 17, 2015 03:55 PM
Aug 17, 2015 09:50 AM
