couple questions about headers and y-pipe
Old Feb 24, 2003 | 10:59 AM
Hyperspeed97z28's Avatar
I'll be installing my dynomax shorty headers and borla y-pipe soon and I need gaskets and bolts still....
so what i'm wondering is what gaskets to get for my headers so they dont blow out and what size gaskets for the collectors on the borla y-pipe, next is what size bolts do i get for the headers, I'm gettin stage 8 lockers for the headers and collectors... the size they offer for sbc headers is "3/8 X 16 - 1" long" or "3/8 X 16 - 3/4" long" and well the collector bolts are all the same.. thanks in advance guys!!
Keith
Old Feb 24, 2003 | 02:19 PM
Nobody knows? I KNOW somebody does....
Old Feb 24, 2003 | 02:49 PM
Geoff Chadwick's Avatar
idk what your headers look like, but for sure the gaskets to the block are copper fel pro. Period. Next, for the header/ypipe gaskets, idk what you've got, might as well measure and take a look. Probably a 2.5" but 3 bolt or 2 bolt? Again, Fel Pro copper. For header bolts, I dont know which length because I dont know how thick the flanges are.
Otherwise,
TTT for ya.
Old Feb 24, 2003 | 02:51 PM
As far as gaskets, I recommend the Mr. Gasket Copperseal header flange gaskets. Make sure you get the D-port gaskets for the LT1.
For the header flange gaskets, make sure the flanges are straight and even. Not unusual to find they are warped, and if you don't straighten them, you will never be able to stop them from leaking.
The Stage 8 locking bolts are a good idea.... can't remember the length.
[EDIT]
Since you have a 97 dual cat setup, and assuming you are installing dual cat headers, they are probably designed to connect to the stock Y-pipe, using the stock "donut" type gaskets... no???
Old Feb 24, 2003 | 02:57 PM
Cream's Avatar
For the header bolts you may want to consider the width of the flange. I bought 3/4 inch with the MACs. However, the flangs were thick and the guy installing them was concerned with the lack of bolt length into the heads. I used the one inch bolts that came with the headers.
However, if you expect to have trouble with space, the 3/4's will be easier to handle.
Micahel
Old Feb 24, 2003 | 04:51 PM
Ive got 95 style headers and a borla y-pipe
Old Feb 24, 2003 | 04:58 PM
Are you saying the Dynomax single cat (i.e. -95) headers do not come with a Y-pipe? Most (but not all) single cat headers come with a Y-pipe, and the Y-pipes are not the same as the stock one.
If you need to connect the collectors to the Y-pipe, get something like the Flo-Tech "dead soft" aluminum collector gaskets. Again, make sure the collector flanges are straight.
rotoruter2001's Avatar
i have heard to avoid the copper ones. That they are really worthless. This seems to be the overall sentiment in my car club and by the local performance shop.
Old Feb 24, 2003 | 05:10 PM
I've had the Mr. Gasket Copperseals on two sets of LT1 headers.... my JBA's (97-99) and now my AS&M's (since 2000) - no problems at all. They have held up to an 800HP nitrous application. I used them, because my buddy, George Baxter used them on his "world's quickest LT1" 97 30th SS convert - 9.04@155mph in a 3,900# car. I can't think of a more difficult application that that one.... .
Highlander
Jan 12, 2020 02:13 PM
Jan 13, 2015 09:52 PM
ChrisFrez
Jan 4, 2015 08:43 AM
