Couple of Opti Questions
Old Oct 27, 2003 | 01:57 PM
Fastbird93's Avatar
First, what' the factory GM warranty on an opti? I got one in the Vented Opti swap kit from Nu-Tek in April, and it's crapping out on my.
Second, the opti drive. Does that just slide off of the opti itself, or is there a particular way for it to be done.
Third: How easy are the opti drive seals (little o rings) to come by??
Old Oct 27, 2003 | 02:15 PM
GM usually warrantees the parts for a year if bought from them.
AFAIK, the drive does not come off.
O-rings are available at the dealer.
Old Oct 27, 2003 | 02:44 PM
Maybe he means does the splined drive shaft (93, 94) just slide in and out of the back of the Opti, or does the Opti just slide forward off the driveshaft. If so, the answer is yes.
Old Oct 27, 2003 | 02:49 PM
Fastbird93's Avatar
Ok, I was under the impression that the drive came off. I'm running a vented setup, so that's all good then. Thanks guys!!!!!
Sergio
Jan 27, 2016 04:27 PM
ChrisFrez
Jan 4, 2015 08:43 AM
Injuneer
Dec 15, 2014 09:36 AM
pologreen97z
Dec 2, 2014 10:42 AM
