Could use bushings...
Old Jul 10, 2003 | 12:51 AM
GreenZ28in503's Avatar
My front end is starting to feel a bit loose. I looked underneath today and noticed that some of my bushings' time have come. I'd like to go poly but I want to do the whole front end at once.
Does anyone know where I could get an entire poly set, preferably sold as a kit for the front end of my 95 Z?
Thankee
Old Jul 10, 2003 | 12:55 AM
DelSoto's Avatar
I just did mine. Prothane #7-227-BL. Got the kit from thunderracing.com
That kit came with all the bushings for the control arms upper and lower. The only thing it didn't come with it the sway bar bushings.
Old Jul 10, 2003 | 12:57 AM
revtime's Avatar
Did mine with an Energy suspension kit I bought from Autozone.
I was an employee at the time and got 20% discount.
Old Jul 10, 2003 | 01:08 AM
Thanks for the info guys. Thunder Racing has been excellent to me in the past so they got my business once again.
All new front end bushings (including sway bar+endlinks) should be at my door in a week.
Old Jul 10, 2003 | 01:22 AM
DelSoto's Avatar
Thunder Racing is one of the F-body owners best friends
Old Jul 10, 2003 | 04:08 AM
ba96ta's Avatar
How easy are the bushings to put in?
Old Jul 10, 2003 | 04:09 AM
From my experience with other cars, it's getting the old ones out that is a pain...but made much easier with a torch. (Burn the rubber not the metal ) The new poly's slide in nicely...
Old Jul 10, 2003 | 06:47 AM
mc63's Avatar
Hey GreenZ28in503,
How much did it cost you?
Old Jul 10, 2003 | 05:43 PM
DelSoto's Avatar
Ewww no...don't burn the rubber itself unless you want to sit there and torch the rubber until it's all ash. Just heat up the inner sleeve until you can drive it out with a punch. Then heat up the shell until you can drive the rubber part itself out ( I use an old socket for that ). It will come out nice and clean and the cleaner you get it, the quieter it'll be down the road. grease em well. Prothane kits come with the grease. The entire front bushing kit minus the sway bar bushings was around 40 bukks.
Old Jul 11, 2003 | 03:07 AM
Will try that method instead....sounds much less stinky.
That Camaro Guy
12
Mar 30, 2010 09:54 PM
RootBreaker
V6 Tech
Aug 12, 2008 11:17 AM
dubbsix
13
Jul 12, 2006 10:58 PM
Hyperspeed97z28
23
Jun 4, 2005 07:46 PM
jcamaro30th
Feb 25, 2005 10:38 PM
