Could this be the master cylinder....
Old Dec 9, 2003 | 09:30 PM
Jerm's Avatar
From: You know when they Quit Suckin that something is Wrong!!!!
Could this be the slave cylinder....
....causing my car not to get into gear?
I've went ahead and was getting ready to drop the tranny and got to the slave cylinder and noted the slave cylinder's rod had quite a bit of play, basically bend it down and pull in and out w/ it.
The other day had to tow my car home due to not being able to grab 2nd getting on the freeway w/ a 4K rpm granny shift. The clutch pedal initially stuck to the floor, then came back up after I pressed it again.
I was unable to get the car in any gear and had to roll off the freeway in neutral.
So is it the slave cylinder?
Old Dec 9, 2003 | 09:40 PM
Jerm's Avatar
Here is a pic linky
Old Dec 10, 2003 | 10:39 AM
Jerm's Avatar
Well, I pulled the sleave off the slave cylinder, looks like it is suppost to bend around like that. I'm guessing it could be the pressure plate, I've snapped a spring in the pressure plate before w/ a Mcleod Clutch at Carlsbad Raceway
I'm just hoping nothing got screwed up in the tranny.
Old Dec 30, 2003 | 02:00 AM
Jerm's Avatar
*update*
Well, it was the clutch disk snapped in two Basically the part of the disk that contains the springs broke off
I've installed a new clutch, an OEM one, but now getting chatter from the throw out bearing Will this chatter cease or do I have to pull the clutch again
Old Dec 30, 2003 | 02:50 AM
LT196's Avatar
what does chatter from the throw out bearing sound like?
G-BODYT56
Jan 14, 2022 11:14 PM
Quickss96
Jan 29, 2016 05:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
1slow93z28
Sep 1, 2015 06:22 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
