Could I put a cutout right here?
Old Jan 23, 2003 | 07:09 PM
94 CAMRO Z28's Avatar
I was thinking, I have my cat removed right now and there is just a 3" pipe welded in place. Could I put a cutout in place there, so basically right after the ypipe? Or would this be just to close to the o2 sensors? I would only run it open to see what the difference would be at the track. And when I wanted to hear my cam even louder
Aaron
Old Jan 23, 2003 | 07:20 PM
funina91ss's Avatar
thats where I have mine on the '91
Old Jan 23, 2003 | 09:43 PM
LT1CST's Avatar
WELL thats a kickass Idea. THe only thing is getting somone to put that in for ya. I have My Cut out after my CAT before my Muffler. Man it rips so loud. ITs bad ***. LEt me know whathappens Chris
Old Jan 23, 2003 | 10:52 PM
97droptopZ's Avatar
I was thinking about putting a qtec cutout after the y pipe also w/ lt's or shortys whatever i end up getting due to emissions. if anybody has this setup let me know, i figure i can save 60 bucks by merging the 2 pipes into one and putting the cutout right there
Old Jan 23, 2003 | 11:15 PM
tbehling's Avatar
i have pondered the same idea, theres only one problem. Having the cut out so close off the engine will lead to a few problems, there is going to be a lack of back pressure and you are going to loose alot of your low end power, mid-high end power will be good though
Old Jan 24, 2003 | 02:31 AM
bad95z28's Avatar
i wouldn't want it that close but thats just me. i'd put it back in before the rear axle.
Old Jan 24, 2003 | 03:09 AM
I know I wouldn't want it that close for daily driving. I just thought it would be fun every now and then, and also I would be interested to see what would happen at the track. Aslo, Im not worried about having someone install it, I've get a welder and I'll do it myself if I go ahead with it.
Aaron
Old Jan 25, 2003 | 12:50 AM
97droptopZ's Avatar
so where's the best place to put cutouts?
Old Jan 25, 2003 | 01:57 AM
LT1CST's Avatar
97 Drop TOP
THe pipe that LEADS to the Muffler. Right before the muffler on the sectoin that angles DOWN thass where the cut out should go. Right near the AXle. It shuld be right Between the INBOUND pipin into the muffler. ANd the OUtBOund Piping that leads to the end of the Exhuast TIPS. ( IF you have DUAL Exhuast) The CUT OUT should be welded RIght on the Downward section pipe that Leads into the Muffler.
CHris
jbrockwell
Mar 14, 2015 08:44 PM
birdblack
Exhaust System
Jan 4, 2015 09:41 PM
wytblur
Mar 2, 2003 03:40 PM
70rs00z-28
Sep 6, 2002 08:13 AM
