cost for cam swap gaskets
Old May 23, 2003 | 03:20 AM
97ss150's Avatar
how much am i looking at for installing my cam? im doing it myself. How much should i be looking at?
Old May 23, 2003 | 04:55 AM
GhostZ's Avatar
Right around $110 for intake gaskets, timing cover set and head gaskets.
The heads are the most at around $34.95 each. Do a search, I posted up all the part numbers and prices a couple of days ago.
Old May 23, 2003 | 05:13 AM
QCKZ28's Avatar
yep that what i just spent on fel pro/gm gaskets (or maybe little more) check out www.thunderracing.com they have an LT1 cam swap gasket kit.
imo the best (cheapest) way to do it is call www.cmotorsports.com and get a cam package that includes almost everything you need. i hear the really good prices. it can get very expensive to change a cam if you buy all the pieces separtely like i did
Old May 23, 2003 | 07:36 AM
You don't need to pull the heads to do a cam swap.
chuyz28
Feb 19, 2015 12:50 AM
InfernalVortex
Jan 17, 2015 09:35 AM
chuyz28
Jan 15, 2015 04:14 PM
chuyz28
Nov 25, 2014 11:14 PM
