Corsa cat back installation: is this a problem?
Old Jul 30, 2006 | 09:48 AM
tcbnj's Avatar
I had the local Meineke shop install a Corsa cat back system on my '95 Formula (LT1). They didn't bother to look at Corsa's instructions.
One instruction item was that there be a clearance of 1/2 inch between the "muffler inlet over axle" pipe and the "outlet tail pipe".
At home I looked under the car at the installation. The space between these two pipes is about 3 sheets of copy paper.
What kind of problems are likely from these pipes being so close together??
Old Jul 30, 2006 | 10:23 AM
1quickTA's Avatar
Re: Corsa cat back installation: is this a problem?
You may hear some noise from the pipes vibrating against each other...thats about it.
rockync7
Jan 1, 2015 05:10 AM
Jul 4, 2005 05:00 PM
tubby
Oct 13, 2003 09:16 AM
Carson96Z28
Aug 28, 2002 05:23 PM
jim88iroc305
Aug 13, 2002 09:24 PM
