Corrupt PCM by interrupting a Tcats READ?
Old May 14, 2005 | 11:11 AM
Eddie95Z28's Avatar
Is it possible to fry the PCM code by aborting a PCM read in Tuner Cats?
Old May 14, 2005 | 11:18 AM
jchevy's Avatar
Re: Corrupt PCM by interrupting a Tcats READ?
When you are reading I dont think you can mess up the PCM. Atleast thats what i have heard. If you aborted a read and its giving you trouble pull the PCM BAT fuse in the fuse block on the side of the dash for about 30 seconds. Should reset the computer.
Dave89IROC's Avatar
unlikely, but I've seen wierder things happen
Old May 14, 2005 | 11:22 AM
Eddie95Z28's Avatar
Well in short what happened was, I was testing the com port with a new laptop for tuning so I just started a TC read and when it started reading I just pressed the 'X'. then when I tried to Start freescan to check for codes it wouldn't connect anymore. Then the doozy came when I tried to start the car.... it just turned over but wouldn't start.
Old May 14, 2005 | 11:25 AM
jchevy's Avatar
did you try what i said above?
Old May 14, 2005 | 11:36 AM
Eddie95Z28's Avatar
Yeah I pulled the puse for about a minute... Nothing. I am trying the battery cable right now. I am not sure if it makes a difference but at this point I need to try anything.
Old May 14, 2005 | 12:01 PM
Eddie95Z28's Avatar
Pulling the neg. cable worked. Car runs again now. Still runs like crap but at least it runs... Panic mode off! thanks!!!
DirtyDaveW
Dec 1, 2016 05:37 PM
ad356
Apr 22, 2015 08:35 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Jazsun
Dec 29, 2014 12:14 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
