Correct Canton pickup for Melling 10554 pump with 242-T pan?
Old May 26, 2009 | 01:54 PM
LT1PoloGreenSS's Avatar
If someone could help me I would really appreciate it, the people at canton have no idea what pickup to use with the Melling Select 10554 pump. I thought it was the 20-023 but I am still not sure. Does anyone use this combination?
Thanks!
Old May 31, 2009 | 10:19 PM
NJLT1SS's Avatar
I went through this same thing a few months ago. I have the Melling select 10552 and the Canton 242-T. I bought the pickup they recomended with the pan, and it was too long. The pickup would hit the pan before the oil pan would touch the motor. This is beacuse the Melling Select pump body is longer. What you need to order from them is the pick up for a Corvette pan. The F Body pan is 7.5 inches deep at the sump, and the Corvette pan is 7 inches deep at the sump. This pick up with the 242-T will give you about 5/16 to 3/8 inch clearance from the pickup to pan. I'm not sure of the part number of the pick up. The Corvette pan part number is 15-240T. Hope this helps.
Nick
Old Jun 1, 2009 | 01:49 AM
Wild1's Avatar
Thanks. I'm getting ready to order up a pan, pump, and pick up.
Old Nov 1, 2009 | 12:26 PM
SC/TA's Avatar
Anyone have the pickup part number that will work with the 10554 pump? I have done alot of searching but haven't found a answer yet.
Old Nov 2, 2009 | 05:20 PM
SC/TA's Avatar
Anyone?????
Old Nov 2, 2009 | 05:39 PM
RamAir95TA's Avatar
I have the 10552 pump (high pressure version of the 10554) and used the 20-023 pick-up.
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 07:11 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
sloppytot
Feb 25, 2015 08:30 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
