Copper Spray A Gasket Question
Old Dec 2, 2007 | 01:04 PM
B-Rad420's Avatar
I am installing some head gaskets right now and I sprayed on some Copper spray a gasket by permatex. I then put the gasket and head on the motor but didnt tighten it down. Well basically had the remove the head to check something out and the spray a gasket has almost dried and most has peeled off. Do I need to buy a new head gasket or can I try and remove it some way or should I just spray some more on over it? The gaskets I am using are Felpro 9966PT's. Thanks
Old Dec 2, 2007 | 01:24 PM
mdacton's Avatar
just spray som e more on it.....you really should not need it.
Old Dec 2, 2007 | 01:30 PM
96capricemgr's Avatar
why would you use the copper stuff on that gasket anyway?
Old Dec 2, 2007 | 01:57 PM
B-Rad420's Avatar
A few people suggested it. I also was thinking that I dont exactly have perfect head sealing conditions either. I am putting heads from one motor on another when neither of them have been resurfaced and I know I have over heated the previous engine those heads were on. So I was just trying to play it safe.
The reason I took the head off is because I am a dumb ***. I forgot that there were 2 head bolts that were shorter than the others. I somehow got them in the right places on the first head but the second one I didnt. So basically after I put all the other bolts in a noticed that one just dropped in and didnt thread in so I thought that the hole was stripped so I was trying to check it out. I tried another bolt and I just happened to get the same lenght one, lmao.
Old Dec 2, 2007 | 01:59 PM
mdacton's Avatar
you can use that stuff but its kind of old school...noone uses it anymore
It is supposed to fill in surface irreularities.....if you have a warped head or something its not going to do much
Old Dec 2, 2007 | 02:20 PM
raroz28's Avatar
I use it on intake gaskets, water pump, etc.... Kinda useless on a head gasket I think.
I like it because if I have to pull the water pump, it'll come off cleaner. I won't have to work so hard to clean the area on the block.
Old Dec 2, 2007 | 02:31 PM
The copper sealant was most often used on head gaskets before the advent of composite gaskets that don't need to be retorqued. If still used, I don't see how it can hurt anything.
Old Dec 2, 2007 | 02:44 PM
B-Rad420's Avatar
Thanks for the help. The heads will probally come off in a few months anyways for some LE1's.
Fatdog2
Feb 13, 2015 08:19 PM
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
