Copper Seal Head Gaskets, need a retorque?
Old Apr 6, 2004 | 10:02 PM
Wicked's Avatar
The ones on the car have about 200 miles on them, and after the install, I never did retorque them. Do they need retorqued?
Reason I ask, is I'm getting some coolant leaking from the passenger side head. Atleast I'm pretty sure thats where it's coming from.
Jason
Old Apr 6, 2004 | 10:26 PM
95_LT1_6SPD's Avatar
it wont hurt to retorque them.
Old Apr 6, 2004 | 10:29 PM
If they were torqued properly to start with (and even if they needed to be re-torqued), I don't see why you should have a leak. I would be concerned. Did you use thread sealant on the head bolts?
Old Apr 6, 2004 | 10:43 PM
Wicked's Avatar
I did use sealant on the studs, however the leak isn't coming from the studs. I can actually see the coolant in between the block and the passenger side head. I think it may only be when the engine is running which is strange, cuase if I turn my key forward the water pump works just the same as the engine running (electric water pump).
I've suspected for awhile that I had some kind of leak, because I could never get the coolant to stay topped off.. But when I started my car ran it for a few minutes, and looked under the car, the coolant was dripping out.. then stoped after a minute or so...few minutes later, I turn the key forward so the pump runs, and nothing..
I dont know, Kinda at a loss.
Jason
Old Apr 6, 2004 | 11:54 PM
Serene's Avatar
im pretty sure that is the nature of copper gaskets, they will leak coolant.
am i right?
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
