Copper Gaskets for the street
Old Dec 13, 2006 | 11:11 PM
Wild1's Avatar
How long do you think copper gaskets will last on the street as a daily driver?
The deck is 0.025 and a 0.020" copper gasket will put me at the outside limit of desirable quench. If I run a 0.026 steel shim head gasket then I'll have 0.051 quench which is a bit more than what I'm looking for.
Otherwise, I'd have to settle for a 0.029 Impala head gasket which will really put me away from desirable quench.
Old Dec 14, 2006 | 11:39 AM
1racerdude's Avatar
Deck the block and run a Fel Pro.
Copper gaskets leak to much water when cold.
Old Dec 14, 2006 | 09:48 PM
Wild1's Avatar
I was afraid of that. I was hoping I could get the head closer to ideal quench without having to pull the block and bottom end apart.
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
CARiD
Jan 27, 2015 06:27 AM
Jazsun
Dec 29, 2014 12:14 PM
