cooling problems
Old Aug 21, 2005 | 09:13 AM
redstriper05's Avatar
cooling problems
OK i've been scratching my head and i think I might have a solution but need some help seeing if I'm right. Heres the deal....i was having cooling problems and tried everything I knew to do from water pump, t-stat, fans, flushing the system, bleeding the system and still the same thing. So went and had the heads pressured check and they were fine. So while I had everything off re-did the engine with upper seal kit. Got it all ready and cranked it today still overheating. I took the t-stat out and ran it to see and it will stay where it is suppose to about second click then it will get around the middle mark which is fine after about 10 or 20 min it get over the middle mark and slowly rises to just below 260 mark and stays there. It ever gets above that. Everything works fans, pump and all. So my thing is should I replace my radiator? I feel like it maybe clogged and the water is not cooling. I am stumped when i take of the cap there are no bubbles coming from the radiator and I bleed the system and its fine so I know it can't be the block. So any thoughts would be great. Thanks
Old Aug 21, 2005 | 09:17 AM
joeSS97's Avatar
Re: cooling problems
I would replace the radiator.Ever powerwash or blow the fins out?
Old Aug 21, 2005 | 09:49 AM
MEAN LT1's Avatar
Agree with above.
Have you checked for debris in front or between the a/c condenser and the radiator?
Old Aug 21, 2005 | 10:11 AM
ya i have washed the fins out and the condenser. Still no differance, but i just got done taking it out and there were paint chip looking peices coming out from the drain plug. So I'm just geting a new one.
Old Aug 21, 2005 | 10:33 AM
ZMAN Z28's Avatar
You can take them to a radiator shop and they can brush them for you. It might be worth it to ask them. I haven't looked much yet, but the cheapest new radiator costs about 200 from Checker Auto. The radiator shop might only charge 20-30 (just guessing) to have your radiator cleaned. If anything, they will more than likely give some advice. Also like Shoebox said, look for debris if you haven't already.
ZMAN
Old Aug 21, 2005 | 10:35 AM
1racerdude's Avatar
Have ya put a manual guage on it to see if it is REALLY hot?
Old Aug 21, 2005 | 10:38 AM
ya just pulled it out no debris in front of condenser and I did the manual temp the other day and was pretty close to dash gauge
Old Aug 21, 2005 | 10:50 AM
1racerdude's Avatar
Rad may be plugged on the inside. The shop can clean it out with a soaking.Take it and let them clean it vs a new one it's a lot cheaper.
BigWil
Mar 29, 2015 12:24 PM
Lt4Z2897
Mar 26, 2015 03:02 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
MattFick
Feb 15, 2015 10:16 PM
