cooling problem 94
Old Jun 13, 2003 | 12:58 PM
96illusionbird's Avatar
cooling problem 94
i have a 94 z28.
I've replaced the water pump and thermostat. The previous owner installed white face guages and the temp guage i've come to find out isn't reading right. Does anyone know how to return it to working order?
also, the car got hot and blew the Coolant temp. sensor out of the head and blew the upper radiator hose in half.
What the hell is going on??
any help is appreciated. Feel free to ask more questions as I'm sure I haven't said everything that will be needed to answer the questions
Old Jun 13, 2003 | 01:06 PM
Kris93/95Z28's Avatar
I would check the basics like is the radiator stopped up, do you have the right cap on the radiator?
Jon97Z's Avatar
I believe that the temp sensor located in the driver's side cylinder head should be the one causing you the inaccurate readings. Just replace it. I think its like $13 at the auto parts store. The sensor on your water pump is for your PCM. If you just replaced your pump, that should be fine.
Replace the hose that's broke...refill the system with coolant, and don't forget to bleed this system when you're done to get the air out. And keep your fingers crossed and hope they didn't damage the motor too bad.
Old Jun 13, 2003 | 01:53 PM
i already replaced the coolant temp sensor...it's the second time the plastic part has blown out of the metal.
i'm thinking it has to be the radiator or heater core stopping it up
Old Jun 15, 2003 | 05:50 AM
revtime's Avatar
Is the coolant flowing? With the cap off can you see it moving when the thermostat opens?
Old Jun 16, 2003 | 12:44 AM
i really haven't looked.....i can let you know tomorrow. What are you thinking??
Old Jun 16, 2003 | 12:56 AM
Johnnynsac's Avatar
I thought the temp sensor was on the Water pump?
Old Jun 16, 2003 | 10:43 AM
akrott1's Avatar
Just curious....
Did you replace the waterpump with an electric version? If so, is it turning the right way? I had previously remembered some people on this board wiring up their Electric water pumps incorrectly causing them to turn the wrong way.
Take it to a Jiffy Lube type place and have them do a cooling flush....make sure it is some place that has dex-cool...
Did you bleed it after your WP install? Maybe it is vapor locked?
Just some thoughts...
Good Luck
Aaron
Old Jun 16, 2003 | 03:46 PM
water pump is still gear driven.
i'm taking wednesday off work and I'll let you know what we find out. We're in hopes of getting it to the track wednesday night
Old Jun 16, 2003 | 06:41 PM
Mtrhds94Z's Avatar
That's the PCM sensor.. the guage sensor is in the drivers side cyl head..
BigWil
Mar 29, 2015 12:24 PM
Lt4Z2897
Mar 26, 2015 03:02 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
MattFick
Feb 15, 2015 10:16 PM
