Cooling Problem!!
Old Feb 14, 2005 | 04:32 PM
5.0camaro's Avatar
Cooling Problem!!
The other night i noticed on the freeway that my temp guage was almost in the red(little past the notch right before the red), but when i slowed down o like 40mph it would come down a little(about 30'). I dont think this is normal since i would think i would run cooler on the freeway then the street in stop and go traffic so was hoping you could give me an idea of whats wrong. I was thinking maybe the thermastate or water pump.
Justin
P.S.- this is on a 96 trans am.
Old Feb 14, 2005 | 05:20 PM
1quikZ's Avatar
Re: Cooling Problem!!
thermostat
Old Feb 14, 2005 | 06:09 PM
All4Chevy's Avatar
If that doesn't solve the problem, check to make sure your front air dam is still on (you don't realize how well it works till it breaks) and not broken off and your radiator is clear of debris.
Bill
Old Feb 14, 2005 | 07:22 PM
5.0camaro's Avatar
yea almost forgot got about the air dam, i'll check that, the radiator cap and then the thermastate.
Thanks a lot, i'll keep you guys posted.
Justin
Old Feb 14, 2005 | 07:27 PM
Z28Nut's Avatar
Bill
Just today I was reading the latest Chevy Hi-Perf and it had an article on cooling. One of the pics was of a third gen air dam and the caption described overheating at highway speeds if it's damaged/gone.
Old Feb 14, 2005 | 08:17 PM
All4Chevy's Avatar
Mine broke off, and even in city driving the temp would sky rocket. Now I have a extra long one on with about 1 inch of ground clearance, but it works great.
Bill
Old Feb 14, 2005 | 08:21 PM
Z28Nut's Avatar
Bill
Good to know symptoms to watch for since the end of my driveway keeps trying to tear the air dam and ORP/cutout off my car
Old Feb 14, 2005 | 09:04 PM
All4Chevy's Avatar
When mine finally broke...i took what was left of it and bolted it to another one that i got from a junk yard to make it hang down longer than normal. The area where they are bolted together gives it some extra give so that it bends every 5 seconds when I scrape instead of breaking.
Bill
BigWil
Mar 29, 2015 12:24 PM
Lt4Z2897
Mar 26, 2015 03:02 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
MattFick
Feb 15, 2015 10:16 PM
