Cooling Issues
Old Feb 1, 2004 | 10:18 PM
Zulu-Two-Eight's Avatar
Cooling Issues
My pre-superbowl party was changing a waterpump, thermostat and IAC valve. I got the waterpump back on, filled, started the car up...I let it idle in place, the temp slowly crept up to about "210*" (or halfway on the gauge). I bled the air out of the system.
I left it alone to idle for about 20 minutes, the temp never passed 210. I drove home (hour and a half on the highway....never went below 200-ish, never above 215.
I used a 185* thermostat (although someone said it might actually be 195*)
Before I changed the waterpump and thermostat, the temprature would stay right around 180, but it would take a long time to get there...like 20 minutes of highway driving. It would eventually creep up to 210 after driving on the highway for a half hour then sitting in traffic for 15 minutes. I don't know if the thermostat that was in there was a 160 (car is new to me) or if it was just stuck open.
So, given the "stock" nature of my setup, does this sound normal?
Thanks....
Old Feb 8, 2004 | 11:17 AM
izzyz28's Avatar
My car does the exact same thing! What's the deal?
Old Feb 8, 2004 | 12:24 PM
fbird95's Avatar
These cars and their whacky reverse cooling. I know you should find the problem and correct, but how about a fan switch to keep it cool. You can put one in for under ten bucks. all you need is a switch and some wire.
Old Feb 8, 2004 | 12:30 PM
AdamZ1LE28's Avatar
What year is your car? If its 93-95, it *had* a 160 thermo....but when they switched to OBDII in 1996, the 1996-1997 f-bodies had a 180 thermo.
Old Feb 8, 2004 | 12:54 PM
I actually figured it out...the thermo that was in there was a 160* one, I replaced it with an OEM one, which I *THINK* was 185*-ish.
calaban
May 18, 2020 06:43 PM
timmy39120
May 8, 2015 11:41 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
MattFick
Feb 15, 2015 10:16 PM
