Cooling Issues
Old Aug 20, 2003 | 08:27 AM
snakehunter's Avatar
Angry Cooling Issues
My car is constantly running really high temperatures. I have changed to a 160 degree stat and flushed the system. What else can I do. Every Camaro I have had has ran hot. I have to turn the a/c on to get the fans to kick on. I have also changed all of the relays twice.
Old Aug 20, 2003 | 08:28 AM
predator's Avatar
well i am sure texas is hot so it is normal but some things are oil cooler and tranny cooler they will help also might want to think about aftermarket radiator
Old Aug 20, 2003 | 08:33 AM
93Z286Speed's Avatar
make sure theres no air in the system? also might wanna get the fans reprogramed
Old Aug 20, 2003 | 08:39 AM
What about the fan override switch offered by RK Sport?
Old Aug 20, 2003 | 09:23 AM
CeeBee94Z's Avatar
Yea that will work and be the least amount of hassle just like the SLP switch...but you might as well just make your own switch and save a lot of money. There are how to's online on how to do it so just do a search
Old Aug 20, 2003 | 09:25 AM
ATMINF's Avatar
Put a Griffin Radiator in and forget about all overheating issues. I put one in several years ago and have had no issues with the heat out in the Mohave Desert(death Valley area).
Old Aug 20, 2003 | 09:35 AM
CeeBee94Z's Avatar
Unless your radiator is broken and it has to replaced anyway why do this?
I would much rather spend a few bucks rather than a few hundred when it is going to effectively do the same thing.
Old Aug 20, 2003 | 01:23 PM
Xscream's Avatar
Is your lower air dam still intact? Have you removed the air ducting going to the radator?
Old Aug 20, 2003 | 01:33 PM
I have not removed that. I have not done any modification to that part of the car yet.
Old Aug 20, 2003 | 01:37 PM
TMDZ28's Avatar
just do that, and it wont go higher than the half mark.
Old Aug 20, 2003 | 01:40 PM
Can you kind of give me a description of what I am supposed to do so I don't take out the wrong stuff?
calaban
May 18, 2020 06:43 PM
timmy39120
May 8, 2015 11:41 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
MattFick
Feb 15, 2015 10:16 PM
