Cooling fans on while car is cold
Old Apr 13, 2012 | 03:19 AM
Tyler0309's Avatar
Angry Cooling fans on while car is cold
I have a 95 z28 A4 for the past few weeks when I start the car the cooling fans come on until the car warms up which takes forever since its cold out plus the fans are are. Also the check engine light will come on until the fans cut off. Why is it doing this??
THANKS for the help
Old Apr 13, 2012 | 04:26 AM
Guest47904's Avatar
Guest
Re: Cooling fans on while car is cold
You have to scan it. Remember OBDI PCM but the connector is OBDII.
Old Apr 13, 2012 | 07:09 AM
The check engine light is causing the fans to come on. Scan for codes. When you solve the code issue, the fans won't be on all the time.
Old Apr 13, 2012 | 09:03 PM
belac350's Avatar
Check the AIR pump if its still installed, if the fuse is blown, the fans run.
Old Apr 23, 2012 | 01:37 PM
sh233252's Avatar
My Fuse was blown when this exact problem occurred to me, I did not know where to begin. Replaced the water pump fuse and everything was working like it should. Thanks!
Britbilly
Jan 7, 2015 08:49 PM
jj71787
Dec 30, 2014 02:15 PM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
USAirman93
Nov 24, 2014 03:37 PM
