cooling fans not comming on Help!!!!
Old Feb 9, 2004 | 05:35 PM
97ramairtransam's Avatar
my cooling fans will come on if i unplugg the maf, but they dont come on when it is ideling ! what could cause this? i need help!!
Old Feb 9, 2004 | 06:43 PM
ttt
Old Feb 9, 2004 | 08:36 PM
ttt one more time someone HELP!!!
Old Feb 9, 2004 | 08:47 PM
Maybe it is not hot enough. You give no info on what the temp gauge reads. Info about the cooling system here.
Old Feb 9, 2004 | 08:53 PM
it gets into the red and the fans never come on!! but if i unplug the maf then they come on and cool the motor down!!
Old Jun 23, 2004 | 11:21 AM
Red95M6Z28's Avatar
Bump for more help!
Old Jun 23, 2004 | 11:36 AM
Originally posted by Red95M6Z28
Bump for more help!
Are you bumping for the original poster? I gave a link with testing info in it. If you have a similar problem, what have you tested?
Old Jun 23, 2004 | 11:40 AM
Red95M6Z28's Avatar
I changed my opti and water pump. Doing so I had to remove the fans. They worked fine before and now they never come on. I know they are plugged in all the way. I guess I should check the fuse under the hood!
ChrisFrez
Dec 15, 2014 03:09 PM
ChrisFrez
Dec 7, 2014 06:01 PM
NewsBot
Dec 3, 2014 12:30 PM
ChrisFrez
Nov 30, 2014 08:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
