Cooling Fans NOT Coming On
Ok guys, my Z's been running hot while at idle and sitting in traffic. When I turn on the defroster to divert the heat, the temperature drops and my fans kick on. The temperature does drop while I'm in motion when the heater is not on, so I'm assuming the fans are not kicking on. I replaced the thermostat today but still it runs high in the same above situations even after bleeding and topping off coolant.
I checked the fuses and all are ok. I took the 3 cooling relays and tested them in the fog lights and everytime I put one in the fog lights worked.
So what's my next move? ECT at the water pump (anyone got pics of this?) or the sensor for the gauges?
Thanks in advance!
Thanks in advance!
Re: Cooling Fans NOT Coming On
Hey man. By-pass the relays by jumping terminals 87 to 30. double check those numbers i havent done it in a while. but the fans should turn on when you do this. if it doest your not getting power to the relay. Check the upper radiator hose when the engine is hot and see if the hose is hot. If its not you got a bad thermostat (I know its new but it happens). If that doesnt find the problem id look at the pump itself. hope this helps ya.
-Paul
-Paul
Well, my temperature goes beyond the last hash mark, right inbetween that and the red zone. I checked if the fans kicked on and they don't. It's been doing this ever since I've owned it and that just doesn't seem normal. The fans DO come on when the HVAC is ever turned on.
