Cooler temps, lower MPH?
Old Oct 27, 2003 | 01:37 PM
Tekprodave's Avatar
My quest for 11's N/A on the stock long block is still eluding me. One strange thing I noticed the last 2 times out is that I saw no gains from cooler air temps. In fact it seemed my MPH was down just a bit with the cooler air. What could cause that?
Dave
Old Oct 27, 2003 | 03:14 PM
Fastbird93's Avatar
Higher humidity?? Humidity is the biggest killer of the LT1, more so than heat.
Old Oct 27, 2003 | 04:35 PM
Tekprodave's Avatar
Hmmm, could be but doubtful. Someone else suggested I might be too rich and the cooler air adding to the condition. I haven't changed the air/fuel from stock.
Old Oct 27, 2003 | 04:58 PM
Seal's Avatar
i was having some heat problems and let me put it like this...
ran the car at 230-220 = 14.4@96
ran teh car at 175-185 = 14.000@99
so i'd say heat is not LT1's friend
Old Oct 27, 2003 | 05:01 PM
Seal's Avatar
running rich will lower's MPH, and make the car run a bit cooler... (1-5)
rnuning lean will get the car running higher, and imporive MPH but VERY bad for car.... richer is alot safer
Old Oct 27, 2003 | 05:41 PM
lt195ta's Avatar
^^^^i agree with seal^^^^
Old Oct 27, 2003 | 05:46 PM
Tekprodave's Avatar
yeah but I'm only looking for .043 seconds and I should be running faster and higher mph with cold, dense air but I'm not. I'm running about the same ET but less mph.
Old Oct 28, 2003 | 07:26 AM
NVetro's Avatar
manual cooling fan mod
Old Oct 28, 2003 | 10:38 AM
Tekprodave's Avatar
Not a bad suggestion but I did that before. I'm currently using LT1 edit to control the cooling fans. It works out better for me that way.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
HectorM52
Jan 31, 2015 07:29 PM
96z
Aug 2, 2002 09:00 PM
snksknr94
Aug 2, 2002 07:31 PM
