Coolent smell only when hot
Old Oct 17, 2004 | 12:25 PM
Red96Lt1's Avatar
Just like it says, I smell coolent only when I'm siting in trafic and the temp gauge reads around 3/4 (on the stock gauge). I can turn on my fans and the smell goes away. I can't find any leaks. I flushed the coolent about a year ago and put in the orange type of coolent. Any ideas? Thanks.
Old Oct 17, 2004 | 12:53 PM
Kryckter's Avatar
Re: Coolent smell only when hot
Here's a guess.
Check the coolant crossover tuve bolts on the back of the heads.
They have a gasket on each siide of the tube on each head for a total of 4 gaskets.
Just jack it up and take a look at the back of the heads.
If you see some marks down the heads underneath these, It may be them
This seems to be a problem I have seen quite a few times.
Check it out, The gaskets are about 5 bucks a peice at a local dealership
Old Oct 17, 2004 | 01:51 PM
30696bird's Avatar
If it's getting to the 3/4 mark it could be boiling over. While you're at home let it idle and get to the point you can smell it, pop the hood and look to the left of the radiator cap at the overflow. Listen for boiling sounds.
Old Oct 17, 2004 | 04:44 PM
Red96Lt1's Avatar
Thanks for the replies. I did pop the hood, and didn't hear boiling. I don't think I would since it is a 50/50 mix. I'll check the back of the heads when I get a chance. Thanks guys!
Old Oct 17, 2004 | 07:10 PM
ShawnMacAnanny's Avatar
Take out your battery and look at the coolant overflow hose. Mine makes a anti freeze smell only when it is hot. Mine never really goes above 175 though, but i have noticed the smell. To me, antifreeze seems to smell more when it's hot, trust me. Drain your radiator cold, then CAREFULLY drain it when it's hot. You will notice that antifreeze smells much more potent when it's hot.
Old Oct 17, 2004 | 07:59 PM
SS RRR's Avatar
Originally Posted by Kryckter
Here's a guess.
I've always only used two. One for pass and one for driver side. Where do the other two go?
Old Oct 17, 2004 | 08:04 PM
xxsaint69x's Avatar
the smell is very common for cars with headers, mine does it to...my solution to this is that i always have my vents blowing air, that way i never smell it
Marcin
Old Oct 17, 2004 | 08:24 PM
)2overt SS's Avatar
Marcin
Really? Now that I think about it.. after I insalled my headers I started smelling, what I think, is coolant. It kinda smells like a moka capichino to me, or something. Do you know why? I never worried about it cuz I pressured tested my cooling system myself and my coolant level never drops...
93 RedBird
Nov 15, 2015 08:24 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
greenzee28
Sep 25, 2015 04:29 PM
damnyankee36
Sep 9, 2015 07:06 PM
