coolant temp. sensor
Old Jul 5, 2007 | 10:05 PM
dhz28's Avatar
how do I check the sensor to find out if it is bad. I have not cleaned the maf yet but would"t a dirty maf cause the car to run bad all the time? again the car runs ruf first 2 or 3 mins then no problems
Old Jul 5, 2007 | 11:08 PM
Testing info
The MAF would be easy to check and clean, so why not do so and rule it out?
Old Jul 8, 2007 | 09:27 PM
Severous01's Avatar
pull the maf wires, if it starts fine and runs decent that's your problem. when you pull the maf it will run in speed density mode, not maf mode.
secondly, the coolant temp sensor should run at about 100ohms at operating temps, and around 6k at around 65*f.
warmeck
Apr 27, 2015 04:34 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
brentbrowning01
Dec 16, 2014 06:35 AM
91Bird305
Aug 8, 2002 12:36 AM
JurisAg02
Jul 27, 2002 11:49 AM
