Coolant Temp Gauge not working??
Old Aug 18, 2006 | 12:07 AM
Gun5's Avatar
Hooked a computer up to my car it idles @ 180 (in 105 texas heat today) and the fuel is where its suppose to be not lean as my mechanic thought.. but my coolant temp gauge is reading 0.. we grounded it and it went max so its working but why isnt it showing anything?
I was thinking about doing a coolant temp/tranny temp dual a-pillar thing if we cant find a way to fix it?? how hard is it to hook the coolant temp one up im gonna let me mecahnic do the tranny one
Old Aug 18, 2006 | 12:12 AM
Re: Coolant Temp Gauge not working??
Check the coolant temp sensor in the head. If the gauge it reading "0" it means the sensor or the wire has infinite resistance = open circuit. Easy to check the sensor using an ohm meter.
Old Aug 18, 2006 | 12:43 AM
Gun5's Avatar
id think its working since the computer gave me a reading.. ill tell my mechanic to check that.. he replaced the sensor already once like 2 days ago.. althought before engine/tranny/rear rebuild it was working so maybe he didnt ground it like i said ill have him check
Old Aug 18, 2006 | 01:20 AM
SS RRR's Avatar
There are two different sensors. The one that feeds info to the PCM is located on the waterpump.
It is QUITE possible he installed the wrong type of sensor. Both sensors have different part numbers. Check shoebox's site for the correct p/n.
Old Aug 18, 2006 | 07:52 PM
LT1_383's Avatar
It's the coolant temp sending unit you need on the drivers head. It's not the same as the sensor.
Old Aug 18, 2006 | 08:51 PM
SS RRR's Avatar
They look exactly the same.
Old Aug 18, 2006 | 09:59 PM
Gun5's Avatar
gonna be putting in a aftermarket orielys one tomorrow
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
cmdeshon
Dec 27, 2014 10:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
