coolant/steam line on back of the heads?
Old Mar 30, 2011 | 05:03 PM
twistedbowtie's Avatar
Question coolant/steam line on back of the heads?
okay so i pulled the heads off my lt1 i didnt notice the steam line in the back of the heads and creased the line.
the only place i have found the line is at gm for 140$ i was gonna try and make the line with brass fittings and rubber hose or maybe even bypass?
any input would be helpful. thank
Old Mar 30, 2011 | 05:21 PM
adam85's Avatar
Re: coolant/steam line on back of the heads?
I see them on ebay a lot and in the classified sections here and on ls1tech. Might wanna try those if you haven't.
Old Mar 30, 2011 | 05:22 PM
my1994z28's Avatar
You CANNOT BY PASS the coolant line,go with your frist choice and use brass fittings and rubber hose or use -6 fittings and braided line.
Old Mar 30, 2011 | 05:23 PM
okay, does anyone know what the size is of the holes? someone told me it was pipe thread?
how much pressure is the line under?
Old Mar 30, 2011 | 05:49 PM
Transporter9033's Avatar
I agree with this. The cross over tube is there for a reason. I think I have an extra one at home, ill check when I get there. Ill also check to see what size the holes are too. Not sure about the pressure tho.
Old Mar 30, 2011 | 06:03 PM
thanks transporter9033. im realy wondering on the size of them holes and to know if i have to replace with something with pipe thread of not
Old Mar 30, 2011 | 07:33 PM
Ok, keep in mind these measurements are going to be to the edge of the threads.
I measured the inside diameter of the steam tube holes and came up with. 440" on a set of mitutoyo digital calipers. I also measured a few banjo bolts (the correct bolts for the steam tube) for a reference and got .5035" to .5040". Also, these are tapped straight thread, not a NPT.
I do have an extra cross over tube if interested too.
Hope this helps.
Old Mar 30, 2011 | 08:06 PM
rednblack94z28's Avatar
I bought my replacement at the junk yard. $10 and I am happy with it. Make sure you get new seals though.
Old Mar 30, 2011 | 09:24 PM
1/4" pipe threads. The holes in the head are not tapered, but people use tapered fittings in them all the time to make up their own hose solution.
Example
Old Mar 31, 2011 | 12:48 PM
so the treads are npt 1/4 threads?
is that considered pipe thread?
Old Mar 31, 2011 | 01:13 PM
NJ-LE's Avatar
Yes, they are. N(ational) P(ipe) T(hread)
Aeroquip may have STRAIGHT pipe thread fittings for aircraft that use an O-ring under the hex flange to seal it if you don't want to heavily dope a tapered fitting's threads.
Old Mar 31, 2011 | 03:29 PM
Its actually National Pipe Taper, but who's counting lol. Also with it only being 1/4", the difference in the amount of thread sealant you would have to use would be insignificant.
Old Mar 31, 2011 | 06:28 PM
how much thread sealant would you guy recommend? and what kind
Old Mar 31, 2011 | 07:36 PM
ARP thread sealer from Jegs or Summit, or Permatex PST from autozone will work. Just put enough on to fill the groove of the threads and you will be fine.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
