coolant sensor part number
Old Sep 16, 2005 | 09:41 AM
GreenZLT1's Avatar
what is the GM/AC delco part number for the coolant sensor in the head. I broke mine while doing headers, put in a cheap autozone one, and its giving me false readings. Im gonna go to the dealer to buy a another one.
Rob
Old Sep 16, 2005 | 09:55 AM
Re: coolant sensor part number
Listed on my part numbers page:
1993-1997 coolant temperature sensor for gauge AC-Delco #213-77
GM p/n 25037332
Old Sep 16, 2005 | 10:09 AM
GreenZLT1's Avatar
thanks!
Old Sep 16, 2005 | 10:18 AM
flusz28's Avatar
i bought two from autozone- one i never used and still sitting in the box. when my car overheated last fall i put a new temp sensor in and the temp gauge needle won't move at all to this day and the car is running at 160*. it shows like 215 on the gauge. i grounded the wire lead and the needle pegged to the overheat zone. does this sound like what you are having go wrong?
Old Sep 17, 2005 | 12:38 AM
GreenZLT1's Avatar
it seems like my car would warm up real quick to about 215, and run normal temp there. When I sat in traffic, and the engine got a little more hot, it would climb higher, to almost 260. It was like the sensor was to sensitive. All this, and my cars temp was still normal.
Rob
Old Sep 17, 2005 | 07:52 AM
flusz28's Avatar
huh, how do you know your engine temp was okay then. do you have a scan tool or something? to make sure it is working right. unplug the sensor and get a piece of wire and shove one end of the wire into the plug and ground the other end of the wire and look at your gauge it should be pegged all the way to the right to overheating. if not then there is maybe a short in the wires or your needle is loose. i think thats the problem with mine it came loose somehow. i will mess with it this winter,tear the dash apart
Old Sep 17, 2005 | 12:44 PM
GreenZLT1's Avatar
I took off the radiator cap, and put a digital thermometer (sp) in their, and it read normal. Everything was fine until I broke my stock sensor, and put in this aftermarket one.
Old Sep 18, 2005 | 07:37 PM
flusz28's Avatar
please post back here when you put the ac delco sensor in. maybe thats why mine won't work right either once i installed the autozone part
Old Sep 18, 2005 | 09:42 PM
GreenZLT1's Avatar
Will do, had to order it. I got ahold of a scantool today, and read the sensor of the water pump, and it was right. The gauge in the dash was off about 30 degrees.
Old Sep 18, 2005 | 09:45 PM
flusz28's Avatar
thanks,finally someone else is having this issue with a new sensor. how much was it?
Old Sep 18, 2005 | 09:52 PM
GreenZLT1's Avatar
I haven't ordered it yet. Im not sure on the price. My dad orders from the dealer, and they bring it out to his shop. I think it was around $20 the last I heard.
Old Sep 20, 2005 | 07:07 PM
GreenZLT1's Avatar
I put the new sensor in, and it fixed my problem
It was $16
Old Sep 20, 2005 | 08:00 PM
flusz28's Avatar
dude i wonder if that's the reason mine doesn't work right?? i would hate to waste more money to not fix the problem.
Old Oct 7, 2005 | 08:40 AM
Castro's Avatar
Oh boy I own a 1992 z28 and I just changed the temp sensor on the block that sends the temp to the guage with an autozone sensor. The brand was "Wells" u guys ever figure if it was the sensor?
parkers Z28
Mar 11, 2016 08:14 PM
FirebirdGT
Dec 13, 2014 10:25 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
