Coolant pushing out of overflow after headgasket replace
Well head gasket on the 2,4,6,8 side blew out on a friends fleetwood w lt1... replaced both head gaskets had heads checked no problems found... bled air out of system for around 30 min.. drove car no problems.... now 2days later water is gurgling in and getting pushed out of overflow tank... is it possible for air to still be in there? any ideas would be great thanks guys
Re: Coolant pushing out of overflow after headgasket replace
Ok well i know rad was swapped out b4 i even touched it... and i know i put hoses back where they were when i took them off... so ill go ahead and ask a stupid ?... where does the res hose go?.. and where does steam pipe hose go... thanks for input
http://shbox.com/1/93-94_hoses.jpg
Reservoir hose goes to the nipple on the filler neck and the steam pipe on the nipple below that on the tank.
Thank you for that i am going to keep it but i did headgaskets on a fleetwood and the setup isnt quite the same... im going to try that view for fleetwood.. thanks again everyone
Yeah, sorry, it's not the same. You have a pressurized reservoir and no cap on the radiator. You don't have the same hoses to mix up. Must be something else.
I never had any trouble bleeding the b-body system.
Sounds to me like there is still a combustion to cooling system leak.
Can you test the coolant for combustion gasses?
NAPA has a test kit for like $40, a shop might test it that cheap but if you buy the tools for the same price this time you have them next time.
Yea i guess that'll be my next route... system holds pressure w pressure tester.. but i know that doesnt mean much lol.. car never overheated cant imagine block being back...once again thanks guys
Combustion pressure is so much higher and gasses get through smaller pores so it is possible to have a "one way" combustion to coolant leak but not a coolant leak.
Bryan
warmeck
Apr 16, 2015 05:53 PM
warmeck
Apr 16, 2015 05:50 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
