Coolant pushing out of overflow after headgasket replace
Old May 26, 2011 | 10:07 AM
Lt1son's Avatar
Well head gasket on the 2,4,6,8 side blew out on a friends fleetwood w lt1... replaced both head gaskets had heads checked no problems found... bled air out of system for around 30 min.. drove car no problems.... now 2days later water is gurgling in and getting pushed out of overflow tank... is it possible for air to still be in there? any ideas would be great thanks guys
Old May 26, 2011 | 10:31 AM
Final03's Avatar
Re: Coolant pushing out of overflow after headgasket replace
Sounds like you still have an air bubble in there somewhere.
Old May 26, 2011 | 11:20 AM
Make sure the steam pipe hose and reservoir hose are not swapped on the radiator. Lot of that happening lately.
Old May 26, 2011 | 11:36 AM
Lt1son's Avatar
Ok well i know rad was swapped out b4 i even touched it... and i know i put hoses back where they were when i took them off... so ill go ahead and ask a stupid ?... where does the res hose go?.. and where does steam pipe hose go... thanks for input
Old May 26, 2011 | 01:23 PM
http://shbox.com/1/93-94_hoses.jpg
Reservoir hose goes to the nipple on the filler neck and the steam pipe on the nipple below that on the tank.
Old May 26, 2011 | 09:14 PM
MachinistOne's Avatar
I assume the heads were resurfaced?
Old May 27, 2011 | 05:42 AM
Lt1son's Avatar
Yea heads were checked for cracks and resurfaced.. was told they werent warped ne way but got em done
Old May 27, 2011 | 05:45 AM
Lt1son's Avatar
Thank you for that i am going to keep it but i did headgaskets on a fleetwood and the setup isnt quite the same... im going to try that view for fleetwood.. thanks again everyone
Old May 27, 2011 | 06:43 AM
Yeah, sorry, it's not the same. You have a pressurized reservoir and no cap on the radiator. You don't have the same hoses to mix up. Must be something else.
Old May 27, 2011 | 07:50 AM
Lt1son's Avatar
Yea stupid caddy's.... ill try bleeding it again and see what happens.. thanks again for the help i appreciate it
Old May 27, 2011 | 08:40 AM
96capricemgr's Avatar
I never had any trouble bleeding the b-body system.
Sounds to me like there is still a combustion to cooling system leak.
Can you test the coolant for combustion gasses?
NAPA has a test kit for like $40, a shop might test it that cheap but if you buy the tools for the same price this time you have them next time.
Old May 27, 2011 | 11:43 AM
Lt1son's Avatar
Yea i guess that'll be my next route... system holds pressure w pressure tester.. but i know that doesnt mean much lol.. car never overheated cant imagine block being back...once again thanks guys
Old May 27, 2011 | 01:46 PM
Combustion pressure is so much higher and gasses get through smaller pores so it is possible to have a "one way" combustion to coolant leak but not a coolant leak.
Old May 29, 2011 | 04:05 PM
MyFastTA's Avatar
I am in the process of replacing head gaskets again because of the same type of problem. I just rebuilt the engine put down new head gaskets, they were leaking combustion into the cooling system but not leaking coolant into the cylinders. I have some pictures of what I found and for sure it was leaking combustion. I am replacing with better gaskets but I found that both banks were leaking the same places here is the link to the pictures. Hopefully it helps you some.
Bryan
calaban
May 18, 2020 06:43 PM
warmeck
Apr 16, 2015 05:53 PM
warmeck
Apr 16, 2015 05:50 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
BMX Dad
Jan 23, 2015 07:00 PM
