Coolant Problem
Old Aug 18, 2006 | 08:48 AM
redlt1z282k2
Guest
Posts: n/a
Question Coolant Problem
Ok here goes. I have been having an overheating while idling problem. I bleed the system and that was fixed. I have also been smelling coolant through the ac vents pretty strongly, and when i put the a/c temp in the middle between blue and red i get a mist that smells like coolant. I have also noticed that there is a lot of condensation and frosting on the coolant lines when i check after i have been driving for a while. The air coming out is pretty cold, not freezing or anything, but it never has been and i had it recharged last summer. Also, whenever i go up a hill and the car has to shift down or if i get on it my fans slow down to almost nothing. I have had that prob before and it turned out to be the belt tensioner. We replaced that and the belt is good and tight so i know that isn't the prob this time.
Any ideas? Hopefully some that are easy to fix and low cost.... yeah right, cheap lt1 fix ...lol!
BTW,
1995 Camaro Z28 5.7, Auto, 2.73s's, FIPK, Throttle Body Bypass, Air Foil, and that's about all i can afford but want to do more,....one day.
Old Aug 18, 2006 | 10:45 AM
joeSS97's Avatar
Re: Coolant Problem
It sounds like you heater core is leaking.Pressure test the system to see it it holds pressure.If not,look closely at the heater core..
Old Aug 18, 2006 | 02:36 PM
redlt1z28's Avatar
Re: Coolant Problem
Ok
Thanks for the Help!
Chris
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
warmeck
Apr 16, 2015 05:53 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
MattFick
Feb 15, 2015 10:16 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
