coolant in the oil?
Old Dec 4, 2006 | 06:38 PM
mrmint69's Avatar
coolant in the oil?
I got some antifreeze in the oil from working on my car. What is the proper way to remove it and is this going to have bad for the engine? I ran the car for one minute and drained it. There was 1/2 a quart more than when i had just oil. Then i ran 5 quarts of old oil for 5 minutes and drained it and changed the filter and added new oil.
Old Dec 4, 2006 | 07:02 PM
CASPER97TA's Avatar
thats about the best you can do. just thoroughly drain the oil and change filter. i dont know that i would have started the motor while it was in there. how did you get the coolant in there?
Old Dec 4, 2006 | 08:49 PM
mrmint69's Avatar
I removed the manifold and some spilled in. I had a car years ago that had a leak and would always be higher oil level each time i checked it. It turned out to be a gasket and the engine was fine. I guess coolant is not the worst thing i could get in the oil.
blac94Z
Feb 15, 2021 09:43 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
FredM
Jun 5, 2015 05:45 AM
Nickster 7
May 1, 2015 09:04 PM
Sandersen511
Jan 13, 2015 03:49 PM
