coolant in the oil?
coolant in the oil?
I got some antifreeze in the oil from working on my car. What is the proper way to remove it and is this going to have bad for the engine? I ran the car for one minute and drained it. There was 1/2 a quart more than when i had just oil. Then i ran 5 quarts of old oil for 5 minutes and drained it and changed the filter and added new oil.
I removed the manifold and some spilled in. I had a car years ago that had a leak and would always be higher oil level each time i checked it. It turned out to be a gasket and the engine was fine. I guess coolant is not the worst thing i could get in the oil.
Nickster 7
May 1, 2015 09:04 PM
Sandersen511
Jan 13, 2015 03:49 PM
