Coolant Level ?
Old Jan 23, 2003 | 11:12 PM
CamaroRob97's Avatar
Coolant Level ?
This is a stupid ? but when u guys go out to your car in the morning or when ever the engines been sitting for hours and u take the radiator cap off is there coolant cuz when i take off mine there is none....but theres plenty in the resivour judging by the indiicator dip sitck, my low coolant light is on but she runs cool, so i think i just need to replace the sensors
Rob
Old Jan 23, 2003 | 11:17 PM
Re: Coolant Level ?
Rob
Coolant should be close to the top of the neck. If the level in the reservoir never changes, you might have a bad cap. During cool down, the radiator should draw coolant from the reservoir if it needs it. This is dependent on the cap maintaining a good seal and allowing the vacuum break that will suck the coolant back into the radiator. That might not be happening in your case. A cap is cheap. Maybe it is time for a new one.
Old Jan 23, 2003 | 11:36 PM
thebrainhart's Avatar
Hey, a quick ? on the cap,
There are two arrows pointing opposite of each other, one has an S or something like that, I'm not sure as I'm not looking at it. My question is, does the cap need to point a certain way? Or will it work both ways. Could this cause the cap not to seal/function correctly?
Old Jan 23, 2003 | 11:41 PM
As long as one of the arrows lines up with the overflow tube to the reservoir, you are good. It does not matter which one.
Old Jan 24, 2003 | 05:05 PM
larson_lars64's Avatar
i just had a problem where i would have to fill my radiator up every day. It was fine when hot and shot some fluid into the reservoir tank, but wouldn't suck it back up again. I put on a new radiator cap and it's been working great now.
Old Jan 24, 2003 | 05:11 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
yeap sounds like a suction prob.
Formula Steve
Sep 19, 2023 08:31 AM
blac94Z
Nov 4, 2015 01:59 PM
Louey
Pacific
Oct 1, 2015 12:37 AM
drt
Sep 27, 2015 04:39 PM
