coolant leak is still there!!!
Old Apr 22, 2004 | 05:29 PM
cridom's Avatar
Unhappy coolant leak is still there!!!
im almost sure the pump isnt leaking but maybe a hose or something but the weird thing is that after driving like 3 mins before temp gets over 180 sometimes i loose the power streering, i figured that the coolant must be hitting the belt and slipping so i loose power steering but i see coolant in the left side of my intake elbow like if some one sprayed a bit of coolant on top of the elbow. where do you think the leak is comming from?
i know its not the bleeders but could a hose have such pressure to spray coolant? i also saw some coolant falling from the hose in the right side of the pump from the metal tube. please help me cuz i just fixed the high rpm miss and the car is running great!!!!
i just need to fix this to take it to the track.
thanks
Old Apr 22, 2004 | 05:30 PM
97z28/m6's Avatar
it might still be the pump. put it in the air while runnig to see what leaks.
Old Apr 22, 2004 | 06:33 PM
cridom's Avatar
so y put the car in ramps and started it and waited with a lamp underneeth for 25 mins and no drops!!!!
y guess is when its running at a certain speed.
i saw that my hoses arent all the way in but good enought you thjink at a higher rpm rate the coolant pressure could make the hoses spray??coolant.
i dunno what it is, is like the leak is running from me.
i have a couple of videos in one of them im pointing at the elbow where somtimes i see coolant please help.
www.archangel-online.net/MOV01316.MPG
www.archangel-online.net/MOV01317.MPG
Old Apr 22, 2004 | 06:41 PM
97z28/m6's Avatar
might be the hoses.
Old Apr 23, 2004 | 06:05 AM
IDOXLR8's Avatar
If you beleive your leak is coming from one of your hoses I would highly recommend going to your local autoparts place and renting a pump to pressurize your cooling system.
blac94Z
Feb 15, 2021 09:43 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Blood type Z28
Apr 8, 2015 11:34 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
dansam
Jul 20, 2002 01:10 PM
